Perform this procedure to enable Energy Saver on a specific port or range of ports.
If you have previously enabled Energy Saver globally, you must disable it globally before enabling Energy Saver on individual ports.
If you have previously enabled Efficiency Mode, you must disable it before enabling Energy Saver on individual ports.
Enable energy savings on slot 1 port 2:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface GigabitEthernet 1/2 Switch:1(config-if)#energy-saver port 1/2 enable
What to do next
Configure an Energy Saver schedule.
The following table defines parameters for the energy-saver command.
Variable |
Value |
enable |
Enables energy savings on ports. The default is disabled. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
